Between piston 1jz, 2JZ which best for evo 3 engine? Anyone can help me. Thank you.
Actually stock evo piston can hold 1.5 with proper afr value...
Common piston people put into evo normally failady, 1jz & 2jz...
If you go for fairlady, yes u can gain a lot with sacrifiying the cylinder sleeve coz u need to rebore 2mm compare to 1mm only with 1jz / 2jz...
If 1jz, the piston surface is flat but when u put into block the piston will be lower few mm from top block otherwise u skim the top block...if u go for 2jz u will get really low compression...u need to play with higher boost set up to compensate the loss from low rpm...
I have tried to put 3sgte pistons into evo previously and i think this piston is the best compare from all three above...the piston is 86mm and top piston is level with top block when installed...ngam2 like standart one...but compression a bit higher compare to stock one...spooling respon was very nice...
If u using toyota piston, go for original toyota piston ring rather than RIK / NPR if u want more safety...
so u guys saying 3sgte pistons are the best for evo ?? what about forged pistons ? :hmmmm:
soryy coz im still noob
(other that ZTH off course)...
