Thanks bro, i'll try to arrange a front 50 back 55..
I think the BS ep200 looks more alike potenza or turanza design already, im kinda suprise eco tires with that thread, block and sidewall![]()
Pattern design can look good but how it perform also depends on the rubber compound. Look at their MY-01 sports touring tyres. Directional design and looks high performance but traction rated B only...
---------- Post added at 04:21 PM ---------- 6 hour anti-bump limit - Previous post was at 04:21 PM ----------
Actually if just want to increase the ride height a bit, can insert rubber between the top of the shock mount and the car's body. The rubber can be made from several layers of used tires pressed/glued together and cut to the desired shape with mounting holes for the bolts. This can increase by about 1-1.5cm, but you need to change the mounting bolt to longer ones to accommodate for the rubber thickness. I've done this before for my previous car in Indonesia, but I don't know if anyone has done it here.
Got, seen before but car becomes much more unstable.....:rolleyes:
