That specific part is the butterfly controller part. But usually if that's broken its easier to just replace the throttle body
all i know is that it's connected from pedal to tb where it controls the butterfly, the only problem that i can think of is the spring has gone stiff maybe. even in wiki it doesn't state the name, it's just state "On many cars, the accelerator pedal motion is communicated via the throttle cable, to activate the throttle linkages, which move the throttle plate"
Parts 52 & 54
any idea bout the price range to replace a whole TB?
What happened with your TB, is that a 4g13/15 vdo TB?
speed up no problem..after speeding..engine sound like gonna off...the person claims that is TB problem..(sorry for the poor explanation)
Have you ever service TB? Is recommend to do it, and is good to try a cheap way before going for the expansive TB.. Is the way that workshop want extra earn, but dosen't consider scam/con![]()
means we cn do it by our own?or recommend to ask workshop to do it?
Consider easy for DIY just need some tools and times..
hv no confident to it by own..haha
Meaning once you lift off your accelerator the idling starts to drop below 800rpm and feels like wants to die off? If yes I think your TB is just dirty. It doesn't look like a modified TB or anything (unless you did some porting and polishing inside the TB) so you probably only need a clean.
Since your mechanic ask to change the TB looks like you need to find another mechanic to clean it, since the first one might not do it.
I did not have the tools initially. Recently got them and did for my spare old car with 180k km on it.
Before
After
Before
After
Use CRC brand Throttle Body Cleaner
do i have to open throttle body or i just need to clean the butterfly?
This topic is to share how to bring out a team and type of engine preparation is needed! N if things goes well it might became true that a team 0-100 member will step up!! I should start with race type...
