Couple of small updates - I installed a Carbing front lower arm bar (also know as a tie bar) today. Carbing is a Japanese company that have been around since the late 70's, specializing in aftermarket suspension parts. The bar itself is surprisingly light and the installation only took about 15-minutes.
It's designed to improve steering response and reduce chassis flex, however it's effectiveness is somewhat questionable as the subframe acts as a pretty decent brace on it's own, but after my initial test drive on the same stretches of roads I travel every day the steering response did seem a bit sharper and the cornering more stable. It bolts to the front of the lower control arm, which theoretically should help stop the joints flexing in their cradles when cornering.
The other thing I installed today is a TRD radiator cap. I bought one a while ago but it was the S type, which was unfortunately too small for my aftermarket aluminium radiator. This one on the other hand is an N type, and fit perfectly. It has a higher boiling point than my previous cap (1.1 vs 1.3) and looks pretty sweet at the same time.
