spoon civic
cps = mivec = vtec
vvti = dvvt = vvt
cps =/ vvti
understand??
need mre explaination
cps = mivec = vtec
vvti = dvvt = vvt
cps =/ vvti
understand??
proton claim it was valve lift...more confure now bout cps![]()
cps works like a v-tec and like a mivec....go watch youtube on this detail
above works by changing camshaft lobe that open and close valve at different rate
while vvti works like a DVVT like an ivtec and as well as campro CFE vvt mechanism.....
while this work by changing camshaft rotation timing....where normal engine the camshaft just follow exact movement of crank while vvt can delay the movement a bit or advance the movement a bit thus affecting the engine performance
actually i've driven the campro cps neo & gen2,
the response actually not much different from the previous iafm model.
the only thing is when at rpm 4.5k to 5k, it will have a surge of power and can feel the FW pulling....greater torque at high rpm. if in technical explanation, i am not good to explain.
juz drop by any proton showroom to test drive the car.....or i can assist to arrange if u guys want to.
already test drive waja cps..pick better than non cps...but still can't beat mivec or vtec i think..just share my ten cents...![]()
is like valve lifting but not same...it switch to high lift when switching..
---------- Post added at 10:06 AM ---------- 6 hour anti-bump limit - Previous post was at 10:03 AM ----------
that rite bro....![]()
What do you guys think?
Endangering other people on the road...
Wira 4G63T vs GTR R35 vs Subaru Impreza - YouTube
(other that ZTH off course)...
