Battery relocation
fazidk
Hi guys....battery relocation from engine compartment to rear hood..
- pros n cons
- advantages n disadvantages
- how long does it take
- cost
Just wondering coz it came up in a book I was reading..
Thanx
Fazid
need to be done properly..if not problem will come if you are unlucky...
Yeah bro that's y I'm asking...I know d damage it will cause if x done proper...but I'm x planning to do it....yet hehe...just something I bump into while reading...
- pros n cons
- cost
Thanx
Fazid
Pros : It lightens the front out (quite significant if you have a sensitive butt like mine) and distributes the weight to the back quite nicely. More space for forced induction goodies. :biggrin:
Cons : You need to have a relocator kit and the wires used need to be industrial grade. Otherwise one fine day you'll find that you can't start up the car. The other thing is the battery will release fumes, you may or may not realize it. So you need to have a properly done box to seal it up and it takes up boot space.
Costs depends on quality of materials used. The sample I saw in my friends car - he used 0 gauge cables which were something like RM50 per meter and about 5m was used. The relocation kit costs something like RM300 then the custom made aluminum box about RM200. Then the spare battery used to jump start his car after a month of using this setup another RM200. Then money spent on getting those orange industrial cables and a bigger alternator about RM400 all in.
So yeah.. it's not exactly expensive but do it right the first time and it won't burn a hole in your pocket :biggrin:
Johnson Lam did it in his Evo X.
I'm also interested.
Hmm, instead. Why not diy a capacitor as battery. :biggrin:
I was learning some electrical stuffs then stumble upon these. Man, this guy is crazy. Look how much weight is saved.
That's bloody interesting! But I have a feeling those caps won't be able to last long with the constant charging and discharging, and normally our voltage doesn't maintain constant, it jumps with a 1 to 2 variance so that inconsistent power will wear out these caps even faster. I guess racing application would be awesome, but for a daily drive I wouldn't risk using this.
Daaaarn....x know it'll cost so much...well scratch out that idea....for now:(
ok heres a quick ghetto setup.
1. what you need is extra thick welding cable wire,u acn get em at lelong.com.my (Its better than mine,now feel itchy hand but too lazy to redo it again)
2.use larger battery at the back of course,if you use NS60,maybe you can upgrade NS70 or even better use DIN66 type, it has more CCA power, so it will crank without an issue.
3.gounding point, one of the important part in the modification,dont use cheap cable for the grounding point,it is as important as positive cable
4.light flickers when braking or using signal, this problem still occurs,even noticeable when using LED bulb. Maybe need to use voltage stabilizers(still in progress,need fund)
pls do at competent wiring shop.make sure wire use big enough and short body wire install properly.if not maybe some stuff at your engine will get problem such as starter always kong or etc...just my 2 cents...
On top of all, DIY relocation of battery to the rear is ILLEGAL in the eye of the law. IF your car kana accident, I am very sure the insurance company will check and they will be happily to void your claims when they have found illegality of the battery relocation...
This is true story from my buddy working at a well known motor insurance company in Maresia...:biggrin:
boot besar ma. Hahahaha
You still single mah!....hahaha:rofl:
---------- Post added at 09:49 PM ---------- 6 hour anti-bump limit - Previous post was at 09:48 PM ----------
What about those cars original with battery already in the boot?:confused:
if stock/standard car comes with battery at the boot is ok.
if sendiri mod, then it is illegal.....
just like car that comes originally with HID...then ok.
if sendiri tarok or sendiri add-on HID, then the abang-abang from JPJ will be smiling sweetly at you during operasi...
Any reasons behind the battery relocation voiding insurance?
safety reasons.
DIY battery relocation, if short circuit, and catches fire.....BBQ the whole car occupants, etc...
safety reasons.
Nowadays many cars accident or not also catch fire already without battery mod.....:banghead::banghead::rofl::rofl:
That day the 3 Lembu Genie crash also burn.....:smokin:
I think that is the cons for having expensive car, either u die @ the car dies, y coz of the spare parts, makers don't want to make loose part, if got oem might as well buy new 1 @ is it coz they pour in RON95.
