Hi guys,
got problem with van toyota liteace premio 1.8cc.
Firstly the problem came by with when i'm releasing clutch from gear 1 to move the car the car like cant transfer any power. Feel like clutch slip but in rough way. car vibrating a lot.
15 years havent change clutch, so change it as mechanic advise.
The problem doesnt go away.
After half year, very hard to change gear nowadays when engine is hot.
When first in morning, can engage gear like normal.
After run in for 10km like that, it's very hard to engage gear.
Done brake and clutch fluid change, gearbox oil chage,change clutch plate and cover and bearing, change bottom clucth pump also same problem.
Foreman ask to change clutch again but i refuse cause jus change in half year time.
I notice in clutch system got two pump.
one is at bottom and one is on top.
should i change the top pump also??
[/URL...
