Agree, some not willing to spend money on good tyres and want cheap tyres yet cheap ones that is not safe to use.
my tires used to be like that on my perdana, but the inner side, didn't realize it till I had a flat tyre as the outer side still had thread.
What caused this to happen? And what car is this?
Was on a Satria. Cause? well, tyres worn and since in the front, the cornering wore the shoulders more then the pattern area....
I see. Thanks for the explanation. That doesn't look like stock tyre size on Satria. Low profile tyres? Stock was like 175/65 or something like that isn't it?
What brands of tires? And whats the treadwear rating?
Second picture shows bridgestone (?) with treadweaer rating of 220? :O
P.S: Thats why uncle VR2Turbo have to open tire shop. We ZTH forum members will gladly promote your tire shop business hehehe
maybe the owner want to wear the tyre until so botak......until ppl thought it was slick tyres used in dragster.
Yup, aftermarket upgraded size of 205/45R16
---------- Post added at 03:52 PM ---------- 6 hour anti-bump limit - Previous post was at 03:51 PM ----------
Not sure what tyres. The condition too bad to even want to check....![]()
Rub-damaged by road kerb.
Mine currently using 185/60. If I increase the size, will it be bad?
Looks pretty bad. Can you see the nylon plies? If yes, better change it.
---------- Post added at 08:39 AM ---------- 6 hour anti-bump limit - Previous post was at 08:37 AM ----------
You are on OE 14" so 185/60R14 is best. Used to have 195/55R14 size but very rare nowadays.
If you want to upgrade further then need rim change too. To 15" then 195/50R15, or 205/50R15 in extreme case...![]()
What's OE? Original rims? I'm not using stock rims. I'm using some Enkei rim but I had no idea what name is that or perhaps it is some replica rim. I'll attach a pic here.
Oh! OE is Original Equipment and Wira is either 13" or 14". The 1.3 and 1.5 came with 13" and 1.6 came with 14", so I put both as OE size.
Enkei is famous Japanese Rims, but they have a local factory in Malaysia. Yours could be local Enkei...![]()
Thanks for telling. I din't know Enkei got local factory.
Or maybe replica haha.
Change like Izso go 15 inch light weight. yum yum.
to the place.
