- Joined
- Sep 17, 2008
- Messages
- 20,673
- Points
- 1,713
i use SPIII leh, so far no problem.
someone mention use ATF for power steering in LYN persona.![]()
Can use power steering fluid for ATF then? Since is kinda vice versa for whoever said that
Fark. Hahahha. I forgot is brake fluid or ATF fluid for steering. HAHAHAHAH
Izso! Last time u fill in what dy? I check back manual need ATF Dexron I/II.
I think we filled in SPIII?
SC, your PS might be filled with minyak kelapa sawit haha.
2,3 times & manage to finish it. maybe I could cut back an hour if I used my other 2T bottle jack in kelisa instead of using them bricks
& luckily no other parts r damage. it's not that hard for kancil but don't know with others cars, next my kelisa, hope it's the same method. but all in all, anything diy is truly satisfying.last weekend changed my kancil brake shoe wit try & error method, since doing it alone for the 1st time I didn't had the chance to take pictures of process. took me 4 hours to manage to finish it when it should be faster than that if let them mechs do it. it all went smooth for the right hand side, just an hour I think but all went havoc for the left hand side, no problem opening it but to install it back caused me problem. y coz 1 of the item with the spring popped out & I manage to install it back but the wrong way. I put it back like the right hand side but actually it's like the mirror side of it. how did I know, I re opened the right side compare them parts &2,3 times & manage to finish it. maybe I could cut back an hour if I used my other 2T bottle jack in kelisa instead of using them bricks
Wah, i changed my brake pads myself but shoes are on a whole different level.
like I said for kancil its quite easy but for bigger cars maybe mechanism is on a whole different level edi
ATF I think more complex, can use in PS but not the other way around....
I use PS fluid or ATF for my K & N last time....
Ya as oiling like you said right? My KNN i just wash and reuse already. Didn't oil.
Might get some ATF to use it as oiling. Since I have leftovers for servicing kelisa haha!
No oil then ur engine very dirty dy lo. :o
No oil to trap them. Just go thru straight.
Yup, K & N filter, the filter element have very coarse opening, so need oil to trap fine dirt....
Damn la, means need to buy the oil then.
I went Commando style for my 206....running trumpet without any filter on it....damn kao brave the mech said to me...1st time he sees people running trumpet on 206...
Put netting or ladies stockings in the front......![]()
I got put my wife stocking but it somehow tear open after a week....Then I put 2 layer....
Engine too hot then. Fine wire mesh.......![]()
Hi senior & knowledgable members ,
