- Joined
- Apr 7, 2008
- Messages
- 1,445
- Points
- 1,648
I am no expert in this field, all through past experience with Wira. Also, did rode a R3 Inspira whereby the shocks are the same but different springs and wheel size. Can noticed less rolls during hard corners while maintaining some comfort.
All I need now is to stiffen a little on the suspensions and drop the heights by few cm, springs would be the best bet.
just to add that u can try these:
- use bigger and wider rims with good tyres
- use lancer gt coils and dampers (make sure it is from LGT), if u dont wanna sacrifice comfort too much
- use thick antiroll bars and front strut bar
- install stiff rings to reduce any chassis gaps
- install full set of PU bushings
- install those chassis foam (it really works!)
these alone will alow for some serious and more focused fun without sacrificing so much on normal ride feel....
