Price survey
pablo_murdoc
Hello . I like to ask what is the price range for do allingment for my 1.3 wira n for installing brake disc front n rear .. please sum1 could share info do to i,m a newbie .. thanks
Sent from my GT-I9500 using Tapatalk
Alignment is between RM 20 to 35 depending front only or rear also.
Change disc, Mod bigger disc or what?
I think i want too use other than stock 1.3 disc brake , any suggestion bro ?
If you have not mod your engine for power not need go extreme on the brakes mod.
1.3 wira should be on disc/drum combination, right?
Get a set of 1.6 wira front ventilated disc and caliper including the bigger vacuum servo, and a good set of brake pads. Rear I will leave it be. Sorry, Price I don't know....
I only know price for alignment RM25 + balancing RM20
for wira 1.6 brake kit try searching in mudah.my
Oh! one more thing. When I said good set of brake pads does not mean race or track pads. Something that works with daily drive temperature. I recommend Trestor Blue advantage pads but to me have a lot of dust but bro. stupidcar also using say for him less dust then his original pads...:driver:
1.3 rotors are solid rotors. Just swapping to 1.5 (vented) already makes a difference, not sure about calipers though. If you want to try the 1.5 calipers, I have a set. Let me know, will let go cheap :biggrin:
Vented will be thicker, can fit it?
I only transfer bigger vacuum servo from my Mitsu to my Wira before. Plug and play only.
All plug and play la. 1.3 and 1.5 are interchangeable (almost everything)
Hehe .. all the part name u mention i never heard before bro , seems i have to know the parts name 1st to understand more rite
1 set brake of gti cost about 1k
front n rear
but..if u just change the brake servo to bigger one..u can feel the brake 'biting' ...obvious
u can start it first la
front n rear
Roughly how much is the cost 4 changing to bigger brake servo ?
