Small jerking
jebatdex
Skudai, Johor
Guys
I can feel small jerking while slow acceleration of my car. While cruising, OK. What I know jerking is caused by:
1) spark plug cable (relatively new 1 month)
2) fuel filter (about 6 months old)
3) distributor (change new one 3 years ago)
4) spark plugs, air filter (all new, just serviced my car)
What else should I consider? I am thinking about the fuel pump (inside the fuel tank). This is since it never get changed, still using original one, the car already 18 years. Should i change it anyway? :confused:
Thanks in advance.
Can you describe the jerking a bit more? After you clutch in? Or clutch off? Or during accelerating? Or what?
Clutch in, during slow acceleration, not pressing the acceleration pedal very hard. Like normal driving, when I want to accelerate a bit, feel like 'semput', but very little tiny semput2 especially in middle gear (gear 2 & 3, like not enough air/fuel). Feels similar to when you drive your car, after you start the engine in the morning and straight away drive it, not warming up.
That is the best I can describe huhu :confused: it is not normal, I know there is something wrong because it does not feel like that before.
Suggest you try a different petrol first. Maybe if you have the budget, consider one RM30 tank of Vpower Racing to clear the fuel lines or go send your injectors for cleaning.
Then DIY TB cleaning. If your spark cables, distributor and sparks are new then it's probably a fueling problem. Very very rarely does the fuel pump spoil. And if it is the fP, you'll have way more problems than this.
What do you mean Vpower to clear fuel line? Vpower can sort of cleans the fuel line?
TB usually serviced after how long? Last time serviced about 1 year ago :driver:
your fuel lines could be clogged.
Seldom hear fuel lines clogged, either fuel filter or the injector itself....:hmmmm:
---------- Post added at 08:11 AM ---------- 6 hour anti-bump limit - Previous post was at 08:08 AM ----------
Guys
Thanks in advance.
When did you feel the small jerk? After latest service, after change plug cable?
Yes.. Vpower RACING (not vpower green) can do wonders with the cleaning agents in the fuel.
TB usually serviced every month for me. But I DIY since it's a very easy job.
And VR2turbo brought up a good point - petrol filter.Get that changed too
OK then, I will DIY to clean TB soonest. Also, will get the fuel filter. Can change la since it is not very expensive. Even original proton almost RM60 only:
http://www.protonparts.com.my/online/index.php?page=shop.product_details&flypage=shop.flypage&product_id=330&category_id=121&manufacturer_id=0&option=com_virtuemart&Itemid=26
Is it better to get this or just buy from spare parts shop (regardless the price)? Or maybe outside there there is better (thus more expensive) filter than proton one?
That's expensive. I bought mine for RM20 and it's ori OEM. Not proton brand la but as long as it works and is good quality, it's good enough.
Btw, TB cleaning isn't absolutely necessary to be so frequent, I'm just stupidly obsessive about these things.
Bro. Izso, I remember you have Oil Catch Tank also right? Then really no need clean so often....:biggrin:
Yeah well about that. The OCT was leaking vacuum and causing a lot of problems for my car. So end up I abandoned the OCT.
So, I will just replace my fuel filter, but no need ori proton la. Thanks for the advise.
But, just thinking, my fuel filter is just about 6 months old, already need to replace? Unless my fuel tank the karat very bad and causing the filter clog fast.
---------- Post added at 08:51 PM ---------- 6 hour anti-bump limit - Previous post was at 03:06 PM ----------
Or maybe is it better to use washable one, for example like this:
http://www.mudah.my/Superpower+Washable+Stainless+Aluminum+Fuel+Filter-23167874.htm?last=1
Who has ever try something like this? Any comment?
Since your fuel filter is quite new, just to confirm whether clean or dirty, what I normally do is remove the fuel filter, give it a good shake with petrol still inside then pour onto a white piece of paper. If got plenty of dirt, change, it still clean, fit back....hahahhahaha
Haha..good suggestion. But can you please comment on my question previously about washable fuel filter? Is it good/worth the money since washable, or got problems later on? Appreciate it. Thanks
