Why is my radiator got mixture of oil wit water? I did flush the radiator n fill it back wit water and flush it again the next day. The result still the same. I wan to know where is the oil leak in and wat is the negative thing will happen?
should b using normal gasket... haiz lot of problem in the list need to repair n check....
1. engine mounting
2. absorbed
3. all the bushes.
4. power steering rack.
5. radiator oil leak.
6. etc
bro will help u on the budget
1. engine mounting - rm45-55 per pc
2. absorbed - go straight for adjustable hotbits, tein, gab, etc....2nd hand also can. look in mudah.my
3. all the bushes. change the important ones 1st, lower arm (rm150 per pc 555 brand), tie rod end Rm60 per pc, 555 or ori proton.
4. power steering rack. - can recond but not sure how much.
5. radiator oil leak. - get this fixed 1st but make sure u dun bring to your mech where u service your bimmer.
I got my 555 tie rod end at RM60 per pair woh!![]()
Ooo ya I think its rm60 per pair kua.....:hmmmm:
today i realize my gearbox oil lever very low... is the break oil can use on gearbox
Wat is the correct grade for 6a12tt manual gb?
