Hi all,
My FLX (at) have been suffering this stuttering/jerking condition (or in layman malay, semput2 or sedu sedu
) when i idle (in any gear) after running fast or after using the aircond for most of the journey. Sometimes even in the morning. I went to SC to enquire but they came up with no solutions.
I also have a OBD2 tool and tried to check any fault codes, none found so i double check by going to a workshop with a PADT tool, same thing: no error codes. Has any FLX user solved this yet?
Problem appeared within 1 month of taking delivery of car (in 2012) and has been happening often since. Really appreciate any light on this matter.
Extra info:
Year: 2012
Mileage: 65k+
Plugs: Normal OEM, changed at 40k
Fuel filter: Changed at 50k
Engine oil: Semi 10w-40
) when i idle (in any gear) after running fast or after using the aircond for most of the journey. Sometimes even in the morning. I went to SC to enquire but they came up with no solutions.I also have a OBD2 tool and tried to check any fault codes, none found so i double check by going to a workshop with a PADT tool, same thing: no error codes. Has any FLX user solved this yet?
Extra info:
Year: 2012
Mileage: 65k+
The event should start at 11.30am (tentitively).. venue and destination will be send out via sms...
