My oxygen sensor
ericmaxman
Senior Newbie
https://fbcdn-sphotos-c-a.akamaihd.net/hphotos-ak-xpa1/t1.0-9/10390148_10204135244281011_1197861050089002343_n.jpg
Anything to be concerned of? :hmmmm:
if the part is cheap must as well change it since u have taken it out.
any symptom your sensor already kaput...??
O2 sensor and cheap do not belong in the same sentence...:biggrin:
Let's see..
Check Engine Light = No
OBD2 Error codes = No
Only possible hints? It was running a bit richer than another BLM during dyno. That's all, actually.
O2 sensor quite sensitive wei. You take in and out all the time something will break. Then fc bad and all that lovely stuff associated to a broken o2 then good luck
Should we clean it in like how many thousand KMs? Or only use till it kaput lol.
Never heard of cleaning them. Probably can try if the error code say O2 faulty, then can take out clean and put back to try. If don't work, then have to change...:smokin:
Along the lines of soaking it in gasoline (do we have that here in Malaysia? :rofl::rofl::rofl: ) for about 24 hours..
