Which 1.6L used car to go?
I changed the stock gearbox to 1.3 clutch pump gearbox (F5M211 VRAJ) as syn from stock gearbox need to replace; which is cost me RM880. After run in the new gearbox, notice that RPM reading is slightly low when run at 100km/h.
Stock is close to 3000++rpm while 1.3 gearbox is show at +/-2800rpm.
Is it because of speed sensor from gearbox is different?
Please advise.. Thx.:confused:
the gear ratios are different.
Just would like to know that what is the RPM reading on the 5th gear when hit 100km/h on the stock gearbox.
Btw, besides 1st gear (3.356vs 3.083), is local Wira/Satria 1.3, 1.5 have same ratio with Putra stock gearbox?
Please advise... Thx
Dude, 1.3 GB are short ratio. Good for acceleration but poor cruising RPM. 1.5 is average. Why didn't you use back the 4G93 parts? 1.8 has relatively tall ratios so cruising at 100km/h shouldn't be more than 2.5 to 3k rpm only.
But he is getting lower rpm with the 1.3 gb.....:driver:
Ya, manage to get lower RPM compared with stock gearbox.
Stock gearbox is at 3000~3100rpm while 1.3 gearbox is at 2800rpm :biggrin:
What was your original tyre size? 205/50R16 is over size, right?
wira original cant remember anymore..ori using the sport rim one not the rim besi one..but gti 205/45/16 original..
Gear ratios on gti gearbox damn long, pick up not nice.
pickup not really nice but to change gearbox gonna cost a bomb..hahaha..
my friend 4g93 using 1.5 gearbox highway cruising cannot tahan already coz rpm to high..fuel consumption too high but ur smaller cc gearbox giving u lower rpm that a magic..are u sure ur car using 4g93..
Wira SE is it? Normal Wira original is 175/70/R13...
Manual 5 speed about there.....:driver:
Got one time I am driving until 120kmh with my friend beside me. I ask him how and he told me the car is still stable but the engine noise very loud. :biggrin:
Yup, older GTi also using 205/45R16 only, better pick up, but much more bumpier.....:driver:
mine the normal wira one..13-16 too much oversize already..hahaha
---------- Post added at 10:38 AM ---------- 6 hour anti-bump limit - Previous post was at 10:37 AM ----------
that why im using 50 series one..45 my rim will easily bengkok la if hit pothole..
It was only yesterday night that I saw one Myvi with large rims low profile tyres. I went and have a look and saw 205/40/R17 there on Hankook tyres.
Your Mivec are on 15?
Wah! your wife loves potholes......hahahhahahha:biggrin:
---------- Post added at 11:42 AM ---------- 6 hour anti-bump limit - Previous post was at 11:41 AM ----------
Very common. I have seen many already, Myvi's on 17".....:driver:
They got money to waste on petrol ma. Also is stressing other parts for having to huge rims and tyres right?
On petrol then yes. More contact surface, heavier tyres and rims.
But stress on other parts depends whether they like fitted rims with too much offset will stress the bearings, but if fit correct offset should not be a problem. Using 205/40R17 is correct up size. Bigger by 2.18% only, so still within the 3% ruling...:driver:
Got one fella I know used to use 18" on his myvi for daily drive but 15" for race purposes. Engine not standard though so pulling those 18" no problem
