So I was reading a bit about turbos and F/C:
One side says that turbos help make use of wasted heat energy and exhaust gases as well as increasing volumetric efficiency, thus making then engine more efficient and saves petrol. This is the case when comparing, say, a turbo-ed 1.6 vs an N/A 2.0 with the same power output.
The other side says that because you increase the volume of air going into the engine when turbocharging, you need to increase the amount of fuel injected to maintain the proper air/fuel ratio, thus increasing fuel consumption.
So, which is it?
Do Small Turbo Engines Really Give Better Gas Mileage?
turbo for increased fuel economy - Ultimatecarpage.com forums
AutoSpeed - Turbo'd for Fuel Economy
So, which is it?
