What do you think?
Have offset and can fit wheels with different PCD as well. Seems like a good thing for me.
Nice stuff. Will not be much of a problem to the car right? Last time Izso mentioned spacers are not that good.
Problems will spacers is they just push the wheels out. If too thick means your lug nut will have less amount of turns on the screw, unless you change to longer ones. Another is most spacer do not have center cone.
For adapter spacer, your offset will come out a lot. Unless you can counter with rims offset....
Izso once said that the rims might fly out. Umm, what does the center cone do?
If the lug nuts are secured with only a few turns probably it will fly out....hahhahaha
The center cone centralized your rims, so less chance of wobble and uneven spin...:driver:
Whaaaaaaaaaat? I didn't say it would fly out! I said the extended stress on the lugs and hub will wear it out if too extreme. Especially the lugs. Spoil faster
Then, are there any spacers with center cone?
I remember it was on this thread.
http://www.zerotohundred.com/newfor...ng-satria-gti-front-bumper-and-spacers-3.html
Not sure of spacer, but some the adapter type have a center cone machined on.
I think he meant aluminum lug nuts came off, not spacers, right?
Yeah, the lugs... Due to the spacers, the lugs becomes easy to get loose?
