[WTA] Carbon Fiber lacquer
Seremban
Hi guys, I just recently bought a carbon fiber wing for my A class, quite cheap around RM1400.
Nk tahu je mane blh repair item ni? huhu knp ade warna putih tu?
if that is the case of epoxy, then there is no way to solve the prob....as the epoxy is already hardened.
I hope the blemish on the cf is just surface blemish....which can be polished off.
How come the problem wasnt spotted during the buying the spoiler?
try polishing it
Thank you, I will try it tonight.
---------- Post added at 10:38 AM ---------- 6 hour anti-bump limit - Previous post was at 10:37 AM ----------
It was all good, I think after 2 weeks it expose to sun light Malaysia's hot weather it became like this. But it came too soon than expected.
Due to our hot and pouring weather, it is always advisable to get it coated as the lacquer layer in carbon fiber is thinner than in conventional paint. In your case, first polish it then do a coating thereafter. I did on mine, so far still looking good as new.
Appreciate so much for you guys' advice, can't wait to go back home now and try out :)
Yes I plan to coat it with other cf parts arrived.
---------- Post added at 06:01 PM ---------- 6 hour anti-bump limit - Previous post was at 12:06 PM ----------
Guys, an update, I polished it and can't seem to remove it away. I am thinking send it to paint shop and ask the situ wet sand it and spray with a high grade lacquer, what you guys think?
if you are using laquer, ask for those with UV stabilizer...
Prevent from being yellowish....
