Best grip vs Price
Tasted Extreme already then go down one step to Max will find it less grippy. I still love them in the VR, now on HPY
Yeah. In fact the only thing that's stopping me from swapping out these tyres is the warranty. This Assy2 is the only tyre I know that has warranty against bulges and stuff.
U shud claim a new one for the side that u kena the curb. :top:
U mean PS3 and not P3S right? :rofl:
I think he meant P3ST which is Primacy 3ST, This is mid tyres only.
---------- Post added at 09:49 AM ---------- 6 hour anti-bump limit - Previous post was at 09:47 AM ----------
what unpleasant experience of you with your previous T1R?
T1-R is only good for aquaplaning resistance. Wet grip is bad, in the dry so, so only and having soft sidewall is good for comfort but not performance as in fast corners.
---------- Post added at 09:58 AM ---------- 6 hour anti-bump limit - Previous post was at 09:49 AM ----------
sifu v2rturbo, how many kms have you run the HPY? in what way it is inferior to the Assy2, apart from the bland sidewall design? :proud:
Did not record the mileage, because I rotate the front tyres to the rear after it got damaged by alignment being out after my gear box repair. By the time I got it checked about 20% was shaved off...:bawling:
HPY is behind Asy2 is performance and handling. I would say probably 20% behind. However it still holds my VR pretty well in dry and wet. Unlike T1-R where I got wheel spin in the wet.
The cons are HPY have harder sidewall so is more bumpy. You can however use a lower air pressure. Harder sidewall, so it is good for corners....:biggrin: Probably slightly more noisy the Asy2, but much cheaper...:driver:
---------- Post added at 10:06 AM ---------- 6 hour anti-bump limit - Previous post was at 09:58 AM ----------
Bulge and manufacturer defect are covered by all tyres, only need to prove it.
GY warranty covers puncture, cuts, bruises and impact also which is d*mn good, but after reading further on the T&C, you better be aware of it.
Treadwear 6.7mm and above cover by free replacement of new tyre
5.5mm to 6.6mm, replacement by credit of the balance of tread pattern
Below 5.5mm no more warranty
Warranty period is 6 months only
TERMS & CONDITIONS
The Goodyear Worry Free Assurance (WFA) is only valid in Malaysia
Present the Goodyear WFA card, original receipt of tire purchase, and damaged tire to dealer where the tire was originally purchased when making a claim
Damages other than those specified under the Goodyear WFA will not be covered
Labor charges such as removal, fixing and balancing of tire shall be borne by the purchaser
The Goodyear WFA programme will be invalid after 6 months from the date of purchase or when remaining tread depth is less than 5.5mm
Goodyear (Malaysia) reserves the right to change the terms & conditions herein at any time at its absolute notice without prior notice
Read more here....
http://www.goodyear.com.my/news/news_article.asp?id=390&pg_tracker=carousel#link1
other than the WFA, the other goodyear warranty still applies? (for manufacturing defect).. some shops say goodyear giving 5 yrs warranty?
hey thunder77, just wondering if PS3 is your only choice? no others?
why not you ask suggestion from the workshop? instead of deciding on your own. will be better lo
unless you are a tyre expert la. lol
T1R are shitty tyres, once hit the curb the sidewall was immediately torn, just bought the tyre a week before the incident happened.
scrapped a lot of curb with my Federal 595 but still going strong.
123S is extreme range mah! Different from Max and UHP....
---------- Post added at 02:08 PM ---------- 6 hour anti-bump limit - Previous post was at 02:07 PM ----------
SX2 worrrr VS 123S
normal manufacturing defect still covers, who uses tyres up to 5yrs? lolzzz
---------- Post added at 05:38 PM ---------- 6 hour anti-bump limit - Previous post was at 05:37 PM ----------
other pattern oso hav this WFA... but Asymm2 is the highest range dat goodyear Malaysia carry la...
WFA as per T&C mentioned. Other normal warranty still valid but claim is measure by thread depth balance and this do not cover the impact, curbing or any thing other the manufacturing defect.
---------- Post added at 07:52 PM ---------- 6 hour anti-bump limit - Previous post was at 07:50 PM ----------
ha! ha! looks like you like to hit curbs, did you teach bro. Izso?:biggrin:
I think PSt tyre is more to those who want to hv better grip, and enjoy speeding car and also better cornering. Previously I js use second hand tyre. My first set of new tyre is Michelin tyre. So far I like it. You can check out the Michelin tyre technology and benefit here.
http://www.michelin.com.my/Products-Services/Car-SUV-LT/passenger_car/Pilot_Sport_3.html
sounds dangerous but seems still can be use that I'm quite surprise
Wah.. many 'paid' members to advertise products now..:burnout:
apply job at michelin malaysia :biggrin:
Work for them they expect you to promote already. Now is time to get paid when you promote....:biggrin:
---------- Post added at 03:58 PM ---------- 6 hour anti-bump limit - Previous post was at 03:57 PM ----------
That would be hard. Cuz all brands would want to hire him la :biggrin:
The truth is no one wants to......:bawling:
sifu vr2turbo tested so many tires already. can setup 'MY label' tire grading (just like EU label).. can be the committee chairman :proud:
EU label, the manufacturers test by themselves under self certification, so MY label won't work and with Sirim around just got no chance......:bawling:
