D.I.Y cleaning sylphy air cond dust filter.
XTEC
step 1. unscrew all this 6 screw.
step 2. slowly pull out compartment & unclip compartment light.
step 3. after comapertment had been taken out, on ur right hand side u will see this & unscrew this 2 screw.
step 4. after taken out that part, on deep inside u will find air condition dust filter located.
step 5. slowly pull it out a bit& 2nd finger press down remaining inside filter *** coz the filter is expand type..
wow u see so damm dirty.
step 6. cleaning time, i use front loading machine washing to clean it.
and i put a little bit softlan for fragant purpose i think & some detergent.
and set timing for 30 min's clean.
set the thing rotate, plik plag plig plag. tat one is ok for ur washing machine won't spoilt.
after cleaning done result. not very happy.
execute plan B.
step 7. flush it with tap water & brush with toothbrush (gosok gigi) won't spoilt filter due to filter is not really paper type.
with toothbrush
slowly brush it every layer & let it dry. final result will be like this.
step 8. install back, 2nd finger pressdown & slowly push in.
make sure is fully push in yah, be carefull the cable.
step 9. after done fix back everything, test the air cond condition.
air fresh, new wind blowing gently, fog haze disappeared immediate & the same amount of air blow compare last time are stronger.
http://z10.invisionfree.com/SylphyForumMalaysia/index.php?act=idx
Interesting. How often do you do this? This is what the air-con mechanic will do yah when u send it in for servicing?
well, minus the washing machine though. I dont think they does that?
got free time.
normally they just blow with air or ask u to change new one.
btw plan do add in charcoal filter in.
Blitz does a nice anti bacteria filter for the AC. I used to have one on my R34. Don't know if there is one for the G11. Would be nice to have. Also, at least it is nice to know that TCM is actually providing the filters on their cars now. I had a friend who opened the compartment to check the filter on his X-trail and found that there was no filter there! Apparently TCM never provided the filter on the X-trail.
how much is the filter bro for ur case ?? is drop in type..
me are using 3M aircon filter (DIY)
I just wonder do sentra N16 got it or not.. im sure it have but do your guys know where it located?
check on the blitz website to see if got or not. If it is there then you can probably get it from wangan
Is the filter make of paper or canvas ? Isn't nowadays aircond filter is replaceable and the price is just Rm20-50
Mine is paper one. The carbon one cost much more. Then I heard some other car make have like plastic ones, just wash no need change....:rolleyes:
my waja is paper type,blm is plastic mesh type.
i dont buy a replacement filter for the waja but i rip out the old filter.
bought a home aircon filter.its an additional filter actually and looks like a tissue.
bought it ai Daiso so its rm5.
cut to shape amd done.
better flow than paper type and seem to have odour removing ability.
will upload pic when i replaced it again probably this weekend as its already dirty.
flow is very slow.
i also used it as an additional filter in front of my k&n air filter to capture all those dead bug from
getting in between the v shape vilter as they are very hard to removed even with an air gun.
