haizrul.azmi
From Facebook
- Joined
- Jun 2, 2011
- Messages
- 24
- Points
- 503
air trek turbo or evo 3?plsd advised
I had problem with my VR before on Shell fuel. After pump feel sluggish, I went home and siphon the fuel out, then went and pump back Esso (That time)Sifus,i need help with my perdana v6. Last night i filled my petrol with Shell which is rare. I normally fill my petrol with petron. Now the problem occur the next morning when the idle suddenly when superb low and when i press the throttle it feels very sluggish and the engine vibrated like mad. Even when it shifted to the next gear there's feeling of vibration when i press the throttle. Like very semput.
The first picture is the idle on P with ac on. The 2nd when in D with ac On. Seems like superb low to me. And when i first start the engine or when turning on the ac on it went down to almost 100 RPM. Checked the exhaust even it blows the air not as usual like instead of continuous smooth air coming out it become like something stuck in the exhaust. My throttle body baru cuci and clean. My air filter pun still clean. Any suggestion on what to check?Will cleaning the ECU be a good idea?I cleaned the ECU like 8 months ago. Thank you.
Please do if anyone know where to get them or has spares. I've been living without using the drivers window like a few months. Been opening my door to access tickets and tolls like my old Iswara. sigh.
Sorry all Sifu, is me again.... how much to replace waterpump? if not mistaken the water leak underneath the timming belt area is the water pump area right?.... just finish repairing my aircond now waterpump problem.... non stop for this month. Really pok kai now
the best bang for the buck is bosch fusion platinum plugs bout rm180-220 for 6pcs.
above that will be irirdiums bout rm360 for 6pcs.
workmanship is quite expensive approx. rm150-180 depending on your mechanic.
Workmanship can buy some more plugs.....![]()
RM30 per cylinder..ouch.
or,RM10 for the 3 cylinder easy to work on and rm40 each for under the intake.
interesting to know mechanic's answer on the labour cost if were ti change only 3 plug on the easy to access side...
Hi guys, I suspect my car's ABS is not working. I was going at 100km/h the other day when a car suddenly made a turn without giving turn signal, I slammed the brake and the front wheels locked up and burned rubber. I was a bit shocked. The ABS light supposed to light up if ABS malfunctions right? But it's not.
Bro's, wld like to know any place I can do some ventilation for my perdana v6 bonnet? I do modification any issue when raining day? Tks
before u start the engine,when the key is at 'on' position all system will run self diagnose and this include the abs module.the light should lit up and turned of after a few second.
if the light did not lit on when key is not on the u have a burned bulb which is why u did not see any warning light.
any pulse on the pedal?
on some tire,it will scream even under abs operation.its just the tire's character.
full lock up meams the abs is not working.if u still feel kickback on the pedal and still lock up means the piston is jammed.
anyway,u shouke get it check as assuming u have ABS is very dangerous esp in emergency as u might confidently slam on the pedal knowing u have ABS on board.
Any recommendation place to do? TksYou need to vent at the right places.....![]()
