Evo 7 differs after change of radiator coolant
satria81
PETALING JAYA
Hi All,
My car was running perfectly fine until I changed my radiator coolant 2 days ago.
I drained the entire coolant and replaced with 04 litres of Mitsubishi coolant and now the issue is as below:
my temperature gauge is showing only 1/4 temperature ( so low ) when driving & when on idle the gauge is showing less than 1/2 which was the normal or usual temperature prior to change of coolant, regardless during drive or when idling.
Anyone knows why is the temp now at 1/4 during drive. All thoughts would be greatly appreciated .
mine is also like that on my perdana. its not really an issue actually.
satria81,
Probably something clogged on the hoses or need to change the thermostat.
You may re-flushing the radiator again...to see to outcome.
good morning pangyau,
if the hoses are clogged, the temperature would be high rite .. ?
mine is showing very low temp.
the best is to get an external water temp meter installed.
satria81,
Thanks for the update.
Where do you source the parts and cost?
Any picture of the parts?
S
Replies
16
Views
3K
sincere1
S
