5lug for ne0
neo83
Johor Bahru
hi all,
can i change my wheel from 4lug to 5lug?
if u say yes..
can i use the Ezora hub wheel?
:idea:
no experience doing it at neo but planning to do this also..
if changing to exora bearing can pnp i think its alot easier..
Nowadays more cars comes in 5 lugs that is why rims manufacturer also follow......
i think so..
:biggrin:
---------- Post added at 11:05 AM ---------- 6 hour anti-bump limit - Previous post was at 10:58 AM ----------
me too..
:biggrin:
drill the holes easier.....look for lan engineering @ mudah.my
oic..
PnP or need some mod stupidcar?
---------- Post added at 08:09 AM ---------- 6 hour anti-bump limit - Previous post was at 08:04 AM ----------
b'coz 5lug is more easy to find offset >38..
I remember its PnP. Any mechanic also can do. Just need to source the hub.
any risk if i drill DansEterna??
depends on the person that drills the hole, so far lan engineering has experience on converting 4-5lugs without any issues.
alternatively u could get the 4-5lug converter, works as a spacer as well.
if want to mod lug only drill hole maybe the most cost saving way..
but if want to upgrade to larger rotor & maybe twin pot along the way maybe can try evo 4 onward brake..cost abit high also have to think about brake pad & rotor replacement part after that..
thanks DanzEterna..
---------- Post added at 03:02 PM ---------- 6 hour anti-bump limit - Previous post was at 02:59 PM ----------
evo4 also 4 lug rite..not 5..
