Gail83
Hello All - Good day to you,
My myvi was trapped in the flood, and the water came into inside. I did tow to perodua workshop, and the help to dry it.
What it's been done are - drain the petrol, change oil: ATF, Engine, etc.
After I collected the car, and there is an issue that indicator AT in dashboard light on. This AT is Automatic Transmission. The impact is everytime, the gear move to higher gear, it will choke.
The perodua mechanic says that I need to change the wire in the gearbox, but they also didn't guarantee that it will fix the issue due they still can't pinpoint the issue yet. If it cannot fix yet, they asked me to change ECU.
I am thinking to have 2nd opinion from other workshop. I stay around Bandar Sri Permaisuri, do you have any trustable workshop that I can go into?
Nb: I can still drive the car, but must be extra carefully. Hence, I am still able to drive it around KL.
And my myvi is the latest model.
Kindly please ask your feedback, and appreciate it much,
Thanks,
Thanks,
