Mod plan - 4g93 na
satria81
PETALING JAYA
Hi all,
I have a satria 1.8 – 4G93 DOHC presently running on a Japanese eternal ECU with code of 6123.
I am unhappy with the performance thus planning to mod in order to achieve approx. 170bhp +/-
I was told I can overwrite the 6123 ECU by fixing an EMANAGE, please advise if it would re
ally work well. From what I know, the best ECU for 4g93NA is the good-old 5537 which was used on the putra / wira of year 1996.
Which sort of pistons & race cams, degrees etc should I go for and all other tips are most welcomed.
Thanks all.
Satria81
You may follow my mod, max 151whp without touching the engine internal.
- 60mm throttle body
- GSR intake manifold and ported to 60mm to match with my throttle
- 272 cam
- hotbit 4-1 & Apexi N1
- open pod air filter
- Idrium spark plug & normal 7mm silicone plug cable
On-wheel dyno : max 146whp & 162nm
- Adjustable cam pulley
- E-manage
On-wheel dyno : max 151 whp & 165nm
All dyno with Ron 95 petrol.
If u plan move ahead this number, head port and polish, 82mm high compression piston should be able to help u.
- 272 cam
- E-manage
hi boyzone,
thanks for the tips.
may I know, what is the code of ur ECU for above set up..
151bhp would suffice..
hi boyzone,
My 1st batch Putra is running with 5537 ecu.
However, u still need e-manage (with ignition hardness) to fine tune.:driver:
hi boyzone,
150 hp at the wheels is around 170 at the crank bro, target achieved :biggrin:
boyzone, neat numbers
HI boyzone,
would it better for me to opt for 5537 ecu and pair with an emanage of my current 6123 ecu would suffice for optimum performance..
---------- Post added at 04:50 PM ---------- 6 hour anti-bump limit - Previous post was at 04:49 PM ----------
bro,
being hopeful to achieve:)
I've always trusted that 4g93 has potentials
HI boyzone,
bro,
Will share my dyno chart once I back to Penang.
Once u plug in with e-manage, stock ecu code number is not important already. :biggrin:
How about independent throttle body mod? Something like 4 Throttle from 4A-GE 20 Valve....
Hi all,
Thanks all.
Satria81
the ecu got chip inside??
what sort of aftermarket part is less..
For northern area, choice for aftermarket part is less ...:bawling:
This is why my Satria with Mivec inside still run with 70% of stock set up.
After bring in Putra with 4G93 inside, just realize that choice for 4G93 is huge compared with Mivec :biggrin:
Nice setup.
Exhaust system running how many inches mandrel bent?
- 272 cam
- E-manage
