Damn it. My Persona Elegance 1.6 Auto same problem. But after I whack a hard corner then I lost the brakes.
After pumping it once, then back to normal.
Yours only in corners leh! Funny problem?:hmmmm:
---------- Post added at 12:32 PM ---------- 6 hour anti-bump limit - Previous post was at 12:31 PM ----------
The servo will surely fit as I does't have strut bar thus should be ok , do you have the spec of the distance between bolt on the servo for the MC in mm ? If so I can measure the one in my car at the moment to see if the specs match .
Thanks =)
Best you measure your Waja one then match to the evo one....
