Hi folks
Not sure if i should open a new thread or just ask in here about BOV
Im new to turbo and my ride is currently in BOT project.
Im down to choosing the EWG and BOV.
Apparantly the tauke suggest me to go with imitation for now to test/feel power before upgrading to the real deal BOV anf EWG.
However im still hesitant on the imitation BOV. how bad are these compared to the original ones?
New fake SSQV and RZ are within rm130 while original is like rm800.
Im worried about compressor surge. Are they okay for at least few months run till i decided which original BOV i want to go with?
rgds
congratshi guys, just bolt on my 4g92 sohc. now planning to change injector size. any suggestions?
bro do u run bot on 4g18 ahany known shop? estimate cost?
point 1 yes many oem (especially mitsubishi) use that location for their MAF....
but got 1 problem for that configuration....
is when u install aftermarket BOV that vented to open air....the engine would stalled/jerking a bit....
Hi all sifus
I have Nissan Sentra N16 powered by QG16DE and I felt this engine 'too weak' for my heavy N16 body with auto tranny. So I plan to BOT
Q1 - What kit is suitable for my engine?
Q2 - How much estimate cost to BOT which I expect to reach around 200hp daily usage?
Hope someone will help me with this matter.
Thanks in advance
BOT easily from RM8k upward if all new stuffs.
If just BOT and want 200bhp, I don't think you engine will last long....
If around RM8k-RM10k I think straight forward to SR20DET or SR16VE should be better option right bro?
SR20DET stock PnP also produce minimum 200hp and quite enough. Any opinion about this bro?
Sorry, I am quite new about engine transplant :dong:
Yup, a 2.0 and with turbo internals will be way better, but you have to get it legally done.
Just like mine is 4G63T, is 2.0 and already 200bhp, but remember to budget for suspension and brakes too.
For stability and safety, it should be my first priority before transplanting my engine. even my previous Myvi also used adjustable for stock K3VE
Should be no problem for Sentra N16 1.6L to endorse 2L engine with turbo? Abam 'J' allow it bro?
Hello everyone here, i need advise from all sifu please help...:hmmmm: ok i have a 4G91, my target is BOT 200hp. Got quoted from a shop as following spec
1) TD04 gsr turbo kit
2)gsr injector
3)ss piping & intercooler
4)bov sqv
5)wiring & ecu gsr
6)81mm gsr piston and bore at machine shop.(4G91 can cope with this bore size)
7)block overhaul
8)boost max 1.2bar / OTR 0.8-1bar
9)1.5mm metal gasket
10)semi engine oil
Optional (piggyback add 1k)
additional add on racing bearing
Okay, the question i hope to seek from all sifu is, is this set up enough to get me to 200hp? possible on wheel kah? Or am i better off with gsr halfcut? :hmmmm:
Thanks alot in advance, hopefully there's someone gonna see this as the last reply is on 2015![]()
, regarding that yes ill be changing to but forgot to mention earlier. currently thinking to get walbro 255 or avs 255 (cheaper) and fuel regulator. Any suggested alternative for fuel pump? as well as any recommendation for FPR? Thanks
rechip recommended?
Thanks
