Hi! I am planning to replace my Campro engine crankshaft with the CFE crankshaft. Any idea where I could find a flywheel that could fit the CFE crank since its 6 bolts rather than 5 bolts?
Thanks!
Thanks!
Hey. Does the CFE Crankshaft lower the compression? Or is it just the pistons?
Why u use it?
Its forged and its alot stronger compared to the stock campro crank. I think there are many horror stories online regarding the stock crank snapping.
http://ubai.my/ubai-fullpage-mudah-my-campro-halfcut/proton-campro-crankshaft-broken-issue-defect-or-coincidence.html
Cause I am going to turbocharge my car thats why I don't feel safe with the stock crank.
Thanks!
Perhaps you can try getting a CJ4A mivec flywheel? From what I remember those are 6 bolt. Johor should have some lying around in chopshops.
How come you decided to choose a CFE crank over a waja crank? Just curious haha.
Its forged, Pope Wagon.![]()
forged but 2 mm shorter in stroke... if conrod and piston stay stock... it will become low com set up like those who use thick head gasket
---------- Post added at 04:32 PM ---------- 6 hour anti-bump limit - Previous post was at 04:29 PM ----------
PROTON CAMPRO 1.6 CFE ENGINE - KERETA DOT INFO
read it![]()
