khchow80
Hi all sifu here,recently i have brought 2002 Waja auto last month.After brought,been change some part as below:
1)10w40 Shell engine oil - Maintenance
2)Air filter - Maintenance
3)Oil filter - Maintenance
4)Proton SP3 ATF - Maintenance (Don't know when previous owner change it)
5)Timing belt - Maintenance (Don't know when previous owner change it)
6)Fan belt - Maintenance (Don't know when previous owner change it)
7)Wiper link - Wiper arm loose so change it
8)Valve cover gasket - Bit oil leaking
9)Petrol filter - Maintenance (Don't know when previous owner change it)
10)Plug - Maintenance (Don't know when previous owner change it)
11)Plug coil - Broken and previous owner just gum it back only
12)Plug seal
13)Water pump - fan blade got lubang
14)Aircond fan motor - Sometime not running
15)4pcs new rim and tyre
16Rear lower arm short - Can't do alignment and rubber spoilt
17)Blower motor - Sometime 'jit jit' sound when on aircond
18)Door switch - Sometime not functioning
19)MP3 player - Ori player sound knob loose
After changing this all engine serve well.But encounter other problem as below:
1)Sometime 'ngek ngek' sound from rear but disappear after wash car or rain(Is that absorber or bush fail?)
2)When drive straight or bumper road,steering sometime 'krok krok' sound (Is that absorber fail or bush?Coz mechanic been told front absober not really good and got scraches)
3)Sometime when pick up,driver door got vibration but disappear when car drive smooth (Is that window assembly problem as don't know it's metal or plastic type)
4)Bit white smoke when cool start (Is that engine oil that i use too thin)
5)Bit makan engine oil
6)Sometime can't start car,it 'tik' for first time start,second start ok already.Been change 1 of the relay in fuse box coz found that broken relay cover,problem solved.But symtom come back this few day.1st start 'tik',second start ok already.Is that alternator problem?
Any sifu can give comment about the funny sound and problem that i encounter after repair?Appreciate all sifu opinion.
12)Plug seal
