Myvi handling very light and got like absorber mounting sounds.
mhdalef
Myvi handling very light and not stable when on a dirty, and got like absorber mounting sounds. Even when at highway. Any possibilities ? When i drive fast the car like moving to the left and right and unstable. Pls help.
Sent from my iPhone using Tapatalk
Check your;
-absorber
-absorber mounting
-steering rack bush
-tire pressure
if your mileage is above 150k km also check;
-lower arm
-tie rod
if slow unstable, probably should check your alignment. sounds like toe/camber is out.
1st check alignment as well as wheel balancing. check tyre if any humps around. WHo knows ur tyre might have swollen
