im no sifus.. but using 270 degree above sure will affect the idling.. normally they uses ficd to increase the idling level for aircond.. discuss with ur mechanic first..
hi guys
im planning to get myself a 270 in 275 ex camshaft
and adj cam pulley for my 4g13 motor
Am i gonna have trouble idling with the a/c switched on?
270 in 275 ex, that's a pretty mild cam la. The a/c might be affected a little but otherwise you'll be fine la.
If it is mild cam, don't expect too much from it, right?
Thanks all....really appreciate it
Can i really feel the performance gain after installing
this kind of cam?
You'll feel a difference for only a certain range, depending on how you set the cam angle. Whether it's significant or not depends on your car.
Put in cam, then lighten pulleys...?
Each have individual functions. You put lighten pulley get lighter engine feel then you say cam working?.....hahhahhahahhahahhahahha![]()
No lah... But then don't you usually do all those together? :rolleyes:
Already mentioned if you want to find out any mod working or not, do one by one.....hhahahhahahha![]()
Ok... One by one.. :slug:
Yup, the slug emoticon is correct. Slowly get them done.....![]()
But when oversize piston and snail is a big bunch of money flying off at once. :stupid:
to the place.
