yung
can u guy share after installed fuel regulator and set how mant fuel pressure and what performance part is installed
If I were not wrong, std pressure is around 2.6-2.8 . I set mine 3.2
wats the different with or without the fuel regulator in stock engine? :hmmmm:
Stock engine have stock regulator, adding one that is adjustable is for tuning. If you have mod your car then you add, if not stock should be good enough....![]()
I've done some minor mods :
1. Drop in filter
2. Ev0 7 cam
3. BOV
4. Walbro Pump
5. Spark plugs
So do i need to add the adjustable regulator?![]()
1, 3, 4, 5 no need. 2 not sure how high your cam, but regulator may help....![]()
Better check with Ah Wah... cos by yr mod list now, you don't really need it. It's more of 'nice to have' rather than 'must have'.
Ya lo....must check with him le.... if its not necessary then i can save money for other things d...
Maybe the pressure was set too high bro, that's why higher FC.
I had mine installed when I chg to TD05. Worrying that it may run too lean before I had dyno tune done, so it was necessary. :)
Maybe your ECU had been reflashed before... if the setting is rich on ECU, a tad higher pressure than stock for the regulator will eat you more fuel. By the way, what is your FC? Mine is about 5.5-6.5km/L in city.
