Carburetor Section
gunnerzz, thx for the tips bro. The weber 32/36 i source it from turbogemini.com; they have reproduction and the ori one, been talking to Mr.Bent for quite some times and base on the info given by him, the weber carb (ori/reproduction) performs exactly the same due to the exact mold/licence pattern, adapter to suit my Nissan is provided by them,pricing for the weber carb is around RM1.4k plus shipping, you can check out their website. Currently they are testing on turbocharging a nissan z24 engine in which i'm eager to be part of their project once it's been fully tested.
As for the local mechanic, been scouting a few area in kuantan, so far many mechanic have never heard of weber and dont dare to touch or swap my stock carb, once they heard carburetor "Sorry la boss...i x biasa buat" Maybe i really need to look for those wshop below the trees or near a cave....lol
i think there is a video on how to tune your weber in youtube.
since your carb somes with the adapter then just diy install it.
u might need some fuel hose as old one might be to short or the nozzle is positiin in a different location.
stock air cleaner have to go right?
on the tuning,i do believe the conpany did set the carb during testing.
u wont have a problem running it after installing.
Most mechanics are now accustomed to fuel injection. If carb, then normal ones only.
You need to find old school mechanic already. My mechanic is, but he is in Selangor. My first 4 cars were all carb, and the 4th one I fitted Weber down draught to it when the original one failed but that was quite a while ago also.
---------- Post added at 11:08 PM ---------- 6 hour anti-bump limit - Previous post was at 11:07 PM ----------
Hi, to all sifu.....i'm a newbie in carb mods and i need some advice or contacts for my old little car project
My Old car: Nissan Terrano 2300cc with stock engine, stock carb (unmolested):driver:
Currently i have few mods in my mind
1. Change the stock nissan carb to a weber 32/36DGV- Weber carb i was able to source from an ausie contact, but i need a sifu to install and tune
2. If everything went smooth on the 1st mod; a blow through turbo setup for the weber carb (pre-jetted); blow through and turbo kit i can supply if exhaust & intake manifold can fabricate locally even better- then again i need a sifu to help me complete this project.
By the way; my current location is at east coast (Kuantan) but willing to travel to KL to complete this project. Hope all sifu here can help.....tq tq :driver:
No:1 I think not a problem.
No:2 will not be easy to turbo a carb.....:hmmmm:
Long time not login in zth forum. Nice to know have other interested in carb especially weber. I also source my Reproduction Twin Weber 45 DCOE from turbogemini.com. Yes to fit in your modification carb don't go to workshop/service centre that cater many clients that come for service or standard repair, they simply don't have time to do modifications. As you said better find workshop under the tree. I'm lucky have friend workshop, I source for info from internet he do the work.
By the way I'm fitting the DCOE to my Iswara :)
Woh! twin side draft Weber 45. Won't the fuel feed be too high for a 1.5L engine?
Not necessarily, just need to properly tune the jettings (idle jet, pump jet, main jet & air corrector also the venturi size) to suite your engine. For now I can get around 300km per Rm50 ron95 (recent petrol price) without sacrificing the power.
It takes me very long time to get the tune I need, but it worth it :)
Fuh! that is pretty good. I had a Down draft on my previous 3rd Gen Accord. The best we had was also a side draft 45 on the 2nd Gen Prelude. Started out with the 40, then 45 with high cam. That was a 1.8L power plant but after total mod can out accelerate the then old model BMW 323i....:driver:
:driver::congrats:
:driver::biggrin::slug:
Oh ya, just for info. When you fit in twin weber, advisable to upgrade your standard ignition system to performance ignition system such as MSD or HKS ignition driver, especially for old car. If not it will be hard to get it properly tuned as you will always running rich.
Sent from my iPhone using Tapatalk
Hi guys its been more than 2 since i log in into ZTH. Nice to see the forums are still ongoing.
Im using Toyota Corolla AE92 sedan. I bought a brand new Aisin or Aisan (couldnt remember) brand carburetor to replace my old carburetor in 2012.
Previously i can go up to 120 km for RM 20 / RM 22 petrol (without air cond).
Recently im having problem with my carburetor, i can only go up to 90 km for RM 20 / RM 22 petrol (without air cond).
Do i need to re-tune the carburetor for some fuel savings? If yes, can you all suggest any experts in this with a reliable service records. By the way, i am from Serdang, Selangor. Preferred the mechanic within Klang Valley.
Maybe you can try the carburetor/injection cleaner first. Also it might not the carb problem, other factor like ignition (distributor, plug, plug cable) also contribute the the poor fuel consumption.
Pm to you dy....:driver:
search u-tiup bruh
Hi unker fred,
I was introduced by madxxxx garage from lyn to you, since his workshop open only on weekday as im working in segambut area.
Can you tune my 4g13 carburetor? was running on ngv previously, now de-kit but the tuning running rich...heavy fuel consumption 200+- km per tank
how much do you charge for the tuning?
and how do i contact u?
i cant pm u :bawling::adore:
I want to ask, last time someone removed one item from the choke section of my old Proton Saga car. It is like in the picture, the one on the left that look likes a baseball bat. Now my car when cold start, before start need to pump the accelerator pedal many times then crank only it can start but need long time to become stable. Need to keep leg on the accelerator for abt 5 mins otherwise engine die. What is the function of that stick and should I ask someone to put it back?
The baseball bat part was actually the cold rod compensator of the carburator. When engine was cold. The cold rod was retract and causing the throttle plate was partially open for cold start...
When you cold start your engine.The engine idling rpm will increase due to partially opened throttle plate...When engine reached the normal temperature . The cold rod will push out the throttle plate mechanism and partially close the throttle plate causing to reduce idling rpm.
Thanks, wow looks like no one visit this thread now.
So is this baseball bat thing, should I ask someone to put it back?
My Saga is the one with manual choke. Do you mean that this cold rod retract by itself (auto?) during cold start or when I pull the choke?
When you mention retract, do you mean during cold start the baseball bat move out or move in deeper to the carb housing?
Without this cold rod right now, is my throttle plate in normal position when I am driving (warmed up)?
