The experience here refers to... when ever you plan to do something on your car, some other unexpected things occurs which burn more money in your pocket
my first experience is when i just bought the car and do notice engine quite old and little sluggish(nut just drive fine and boost well, just sluggish than new).... so i decide to do a major overhaul of it... plan to change the cams to high cams (basically upgrading all engine head component), use back stock block internal with new piston rings and acl bearings etc... ended up on the spot buka engine, wash clean piston check, piston groove crack and engine block bore got bigger, ended up burn pocket buy forged internal sekali gus
second experience here happened recently whereby i am upgrading engine management and plan to do dyno tune sekali(my place without 4wd dyno and before this all on the road tuning) , so bought one 2wd GB to change for dyno tune.. during the progress found out my front brake hose already got a more than 90degree bend(luckily no burst yet
) ... and my clutch gt slippage
burnt more money to fix cause expect can change gb and done already
somehow i dont know should happy or sad cause burn money but lucky discovered the brake hose problem before it burst and cause accident
lets share our experiences here
