What is your definition of "not as good as"?
In the sense of engine not picked up as good as the Castrol one.
Ya. Wonder why.You mean acceleration isn't as good? Both also 10W40?
What brand would you recommend for Proton Wira car?
Currently using FUCHS but seems not as good as Castrol Magnetec I used in the past. Thinking of trying Shell or Petronas. What's your call?
Just go to Tesco or AEON and buy which ever popular brands (Mobil, Total, Shell, Castrol, Petronas, Mitsubishi Oil/Eneos) available there when on promotions (around rm80-90/4ltr) coz that's very good value for money. Should be good enough for your Wira.
No wonder Tesco sells, so much advertisement from us......hhahahhahahha![]()
Just wondering.....I am currently using Total 5w30....But then, Malaysia weather so hot couple with my engine being turbocharged, wouldnt it be too much heat for the oil grade to take? I mean i am just guessing la.
What do you guys think? Would the viscosity for the 5w be very thin and cannot protect the engine with the heat that its going through?![]()
dont worry abt the front fiigure as its for cold climate country which we arent.
only worry abt the rear figure.
why there is 2?
because its multigrade oil which is design work on wider climate.
nowadays all modern engine are recommended to run on x30w.
this is due to the near perfect tolerence the manufacturing process can achieve.
old engine are most suitable on thicker oilxw50 to reduces oil consuption and increase protection as the wear and tear is going to be huge.
its something like that.
however,castrol edge have xw60 for track purpose.
can u ised it daily,yes but with compromise on usable performance and ftankly its a total waste of money.
highest u can go in my point of view is xw40.if the current service center 5w30 is super expensive.
but sc wont do it as to avoid their so called warranty.
the current fill your sc uses are of api SN grade if not mistaken which supposedly has super eco friendly substance and quality and which is why its super expensive.
at tesco i doubt there are oil besing sold with high api hrade like that.
what important after yr oil grade is to change it on time as yrs is turbo engine.
even i'm on na,i change less than the so recommended oci as the oil at tesco are too cheap.
heck i used their fs oil for only 5k km.
so will be with the total energy my waja is on.
Well, the oils sold at Tesco do have the same rating as others and they're the same well known good brands like Mobil & Total. The last oil I bought which is the Mobil 3000 5w40 is also rated as SN oil. Total 5w40 there is also SN, as well as the other brands like Castrol, Shell, & Petronas. I'm doing OCI in my Mark X at 10k km using oils from Tesco/AEON (Mobil, Eneos) for many years already and no problem what so ever. I think you're wasting your money changing it at 5k intervals but it's up to you what ever gives you your peace of mind I suppose.![]()
well,all this while i am using oil from outside shop so its expensive and i did it at 10k km.
now,oil is cheaper so can change earlier.
i even used the Tesco brand fs oil in my campro.
not to bad compared to known brand of fs oil.
this is the oil i change at 5k km.
its sold at rm89...half the price of reputable fs oil amd only a tad more expensive than some mineral or semi oil.
Many of the oil sold in Tesco is SN rated already. I even saw Shell New Pure plus technology Helix Ultra being sold there...
Oh you mean the Tesco brand oil! That one I never try, and most likely will never too coz I only want to use brands I know will be good. IMHO it's best calue if buy Mobil/Tota/ etc2 FS oils at Tesco when on promotion coz only rm119-149 but can last 10 k km.
Yeap exactly.
I have tried Mobil 1 before and it was at super bargain price.
Too bad my engine does not seem to interact well with the oil.
Maybe its been running on Total all along so I started using the total 7000 energy.
Super cheap, 5l packaging..what more can I ask for as my Waja needs 5l of oil.
For the Tesco oil, my BLM is still using it and previous oil was drain at abt 5k km.
