Inspira Fuel consumption
Inpira 1.8 mt.stock engine..k&n drop in filter.
Retune ecu..for better pickup n topspeed..
70% hiway 30% normal road.
Air cond on...
3 adult inside the car..
Maintain 100kmh on hiway..just 80km distance
This my fc
To All Sifu,
Need urgent help, i just buy a second hand Inspira 2.0P year 2012 latest spec with R.camera, 81k km mileage.
Car engine and CVT all smooth, only suspension got "klak klak sound" very bumping road got light sound.
But bigger problem, i did messure every time, i always refill 50 to 51 litres of Ron95 (when empty), every full tank of 50 litres only city drive 395km to 410km.
this compare with my wife year 2008, honda accord 2.0, Honda got better fuel economy, at 50 litres @ average 490 km.
i found at Mudah, some workshop can do A/F tune and gear shifting tune, will this help to improve on engine performance and fuel consuption???
Thanks,
Any member Help to advice,
As below show remap like very cheap and maybe can improve my fuel consumption and pickup for slow CVT respond, help to comment here...
http://www.zerotohundred.com/newforums/attachment.php?attachmentid=546818
Seems like my fuel consumption is on the high side as well. Based on my last refuel, managed a 7.76KM/L (400KM, 51.55L - this is when these is no bars left on the fuel indicator). 10%highway, 90%city in Penang.
Mine is the 2.0E CVT year 2012. Only thing changed was the filter to K&N drop-in.
yup...last time i drive like maniac achieve 6KM/L...now i do 9-10KM/L....
lower than 8KM/L considered crazy already...
all figures are based on dash meter...not actual calculation...
The calculation i got is between the petrol volume from receipt (51.55L) and the mileage shown on the dash meter (400 KM). This is the consumption result after I just serviced at Proton.
Total mileage now at 44k+.
However max i ever managed on a tank of Ron 95 gas with 90%highway and 10%city (Penang to KL and back to Ipoh) was about 550-575 KM with travelling speeds between 110-130km/h. Not too shabby i would say but could be better.
So far had PMed a few members of ZTH regarding Inspira ECU remap but no luck on replies yet. Anyone to recommend? I wouldn't mind travelling to KL to get it done.
try Kenny at Jalan Klang Lama
012 259 7929
To All Sifu,
Thanks,
Try to check your Lambda and CO reading from the exhaust gas. That may tell you if your engine is running a bit rich or still normal. If a bit rich then need to adjust the Air fuel ratio. Another thing that you might want to try is carbon cleaning and check your injector spray pattern.
But the factor that most affect fuel consumption are traffic and your driving style. If you often go thru traffic jams then difficult to get good fuel economy. If your driving style is not smooth, also your fuel economy won't be as good.
Dash econometer is not accurate at all. It only tells you your average at that point in time, not the real average.
For mileage calculation I normally fill to the brim, set trip meter to 0. Then drive around, refill to the max then divide by the mileage done on trip meter
feul for my cousin lancer gt and my myvi almost same.......rm150/month....donno why:confused:
Cannot compare like that. The normal routes between you two may differ hence different distances traveled, the fuel prices are also not stable, driving style also can be different.
the biggest difference is the big diff weight of both cars...
Hi Protuner,
Need more detail on your review on Kenny works, he can do remap as Air fuel and Gear shilt timing?
Result good?
Thanks
Gear shift is TCU, not ECU..
for his works, go to lowyat forum...
everybody can do remap...what important is tuning...he will explain everything..
want to remap until engine blow also can...
Another remapper is Tomen.. in FB....lost his number BTW...
As per mentioned by bro. 6UE5t, monthly spend how much is not the way to calculate mileage.
Best to calculate distance / liter
