Merdeka evening wen to midvalley. After hangout going back time car canot start. Car can crank as normal. But cant start.Battery is still OK.all electrical can be normal function. Open rear seat check fuel pump, pull out the outlet hose from fuel pump. On ignition, fuel spray out. Check infront fuel gt naik or not. Found fuel naik after on ignition. And the pressure aso high. Check for api. Place a wire at spark plug cabel and ground it. Found api. I have no idea wt course can make the car cannot start. Any idea y the car cannot start????
