Izso, the engine was down for a rebuild so just add when it was assembled.
pomen, brake fluid is corrosive wei....
Corrosive on paint and copper...
i wouldnt try brake fluid....
but if i got a whole lot of glycol (ethylene glycol) then maybe i'll try using it in pure form...
well...since u were saying brake fluid...
here is what i found:
https://en.wikipedia.org/wiki/Brake_fluid
DOT Brake Fluid vs. Mineral Oil - and the Winner is.. | Epic Bleed Solutions
DOT3 brake fluid boiling temp was exactly at 190degree C...which makes the evan waterless coolant sounds pretty much like a brake fluid...
plus brake fluid also content GLYCOL which is also happens to be content of a coolant![]()
Waterless coolant sound very appealing due to the fact that it can minimise rust issues to almost zero. But I am having reservations as to what chemicals are they using that has to ability to match the specific heat capacity and specific latent heat of water. Up till now, nothing beats water in terms of cooling. But I'm waiting for the famed myth-buster sifu for his review![]()
You can't. ethylene glycol by itself is corrosive I think. And the heat transfer properties is poor if I remember my chemistry 101.
Aiyo.. it's not brake fluid + ethylene glycol la. It's probably some petroleum based chemical mix with ethylene glycol la.
if change water pump need to pay rm300 for top up?
This Evans Waterless Coolant sounds like a really good product. But i have to agree, it is really expensive for a coolant. RM600 to do the whole thing. And if anything happens which requires a top-up, is another RM300 a bottle. That damn painful. But where to get it in Malaysia?
What about that Engine Ice? Where to get it and how much does it cost?
Can Try Lubegard Kool It also.....
Gosh is it corrosive?? Never knew that. Anyways, I've seen some brands that are slightly more expensive using propylene glycol now.
Lubeguard kool and Engine Ice is like Permacools premix. These are already premixed coolants from what I can make out in the website. Meaning they are glycol based products mixed with water. Engine Ice is Propylene glycol mixed, Permacool is ethylene glycol mixed, Evans has is both propylene glycol and ethylene glycol but oil based somehow. Not sure.
Glycols generally are good conductors of heat but are flammable. So not sure how that works for us as a coolant.
Evans has a distributor in KL, forgot the name. Need to dig out the name card I took the other day.
Not exactly, they sell in 4L bottles, since each bottle is RM300 then yes. But it's not per top-up. However if installed correctly, there shouldn't be any need to topup if there's no catastrophic failure in the engine head gasket or hoses.
---------- Post added at 08:17 AM ---------- 6 hour anti-bump limit - Previous post was at 08:16 AM ----------
in its pure form it is I think. premixed it isn't but it still will break down due to the water combination, hence the need to change radiator water every now and then.
New car coolant can last because no corrosion or breakdown of coolant inside the system. If diligent and change every x amount of KM / years, then it'll never have issues I personally think.
---------- Post added at 07:14 AM ---------- 6 hour anti-bump limit - Previous post was at 07:12 AM ----------
After thinking about this a while, I've decided the following :
1. Radiators and hoses are inexpensive. My old car radiator brand new was less than 300 to buy. New hoses 30-40 each.
2. Coolant is cheap to buy. So is distilled water.
So no matter how I calculate I cannot justify the cost for a waterless system (600). So my conclusion is unless someone is sponsoring me to do the test for them, I'll never spend a cent on this system.
This topic is to share how to bring out a team and type of engine preparation is needed! N if things goes well it might became true that a team 0-100 member will step up!! I should start with race type...
