One side tyre wear problem
My friend had a similar problem, due to previous owner met with an accident, caused chassis to not be aligned. Sent to bodyshop, re allign the chasis and never had issues
Or the tyre shop your going to might have be using tools which are not accurate or not calibrated properly, try another shop
What about brake balance? Ride height same between left n right? Have u changed to new absorber top mounting only on one side before?
i like parada tyre...quite grippy but soft sidewall...good for comfort driving with rare spirited driving..just complain about the noise... :biggrin:
btw...that sure confirm camber problem..need more kangkang....
last time while im using parada......right tyre camber -2. and left camber -1.5 (right more than left because compensate more to highway exit ramp)...
your case more like roundabout too many in your place...so set left camber more than right,.....that should be solving your problem right away.....
Changed both moutings....
Bro that is a very good suggestion. I will keep that in mind! Thanks! This might just compensate for the roads around my area.
But by the looks of your tyres, inside and outside even wear woh! Play with camber if your tyres wear either more on inside or outside....:driver:
D
Replies
7
Views
8K
dude7942
D
