Brightness is pretty subjective, and lots of ppl think that the higher light temp (in k), the "better" their lighting, as in 3000k is better than 4000k.
Improvement of lighting isnt dependent on bulb itself, but the lens, reflector housing and the light source, its quality. Sometimes, the ballast, the gauge of wiring, earthing, etc.
Of course, car enthusiasts mostly play around bulbs, when they wanted to upgrade their headlamp.
My previous car lighting improved somehow, when I changed to Raybrig multi-reflector lamp only. The ori H4 bulbs were retained.
Why ah? TT?......![]()
HI, since we are on fog lights. Have any one tried Phillips Xtreme vision 100% (3500k) and PIAA northern white star (4400k) Bulbs?
I cant make up my mind if I wanna have 4400k on my headlights or on the fog light. Got all standard halogen bulbs on my lowbeam & fog.
Guys would you go for a yellow but brighter 100% bulbs or whiter but no so bright bulbs? Or just keep the standard lowbeam and change a LED fog light bulbs instead?
Please help , cant really make up my mind here.
No lah, need some help to purchase a part. Do pm me if you are located nearby jalan ipoh.
Thanks
Wah! so now is 4 projector lights.....![]()
what to do, can't see at night.
JB still ok, got road lamp..
when go back to kampong, its worst..
anyway its a much cheaper or better solution as compare to the aftermarket projector headlight.
I was told these headlight won't last and many negative complaints from perdana owners.
something that I have done over the weekend.. (of course, not done by me..)
a new square 4.5" projector with HID, a replacement over the main light, while the previous projector switch to the other half.
the configuration is as such, both light will on for high and low beam.
hopefully with this, the journey of better light, will end.
So far, improvement than previous.
As for highway drive, can only be known when I go back to Ipoh this Xmas.
Bro, i spot a pivot raizin there. Is it voltage stabilizer ?![]()
PUTRAJAYA: The price of premium grade...
