Will keep an eye on the forums about TT bro...![]()
But you have to look out for Penang TT woh!......lol
But you have to look out for Penang TT woh!......lol![]()
Which is like very rare??
Not sure, probably you can post a tt thread for Penang and see the response......![]()
Just asked for monroe reflex abs at a spare part shop. The owner told me even he couldnt find it. haha! Will try asking other shops too and will try to save more money till then..
If cannot find ask the importers.....
http://www.monroe-sea.com/distributors.html
If you're under a tight budget can consider HWL adjustable with hi/lo/soft/hard... 15 steps version less than RM1.5k.
I just remembered another brand that I remember using that was slightly better than Monroe. Sachs. This brand was quite good in terms of stiffness and car control. Maybe you'll have better luck finding this brand.
That's quite cheap, brand new set?
Yup brand new since now competition is quite high for shocks, you can get these kind of prices for entry level Hi/lo/Soft/Hard wth 12-16 steps adjustable
Does spare part shop carry this??or must look for performance shop??
---------- Post added at 10:47 PM ---------- 6 hour anti-bump limit - Previous post was at 10:38 PM ----------
Ok sure....Which one will u recommend between the HWL h/l/s/h, and the sachs? cause u always recommend to get coilovers with h/l/s/h..so i just wanna make sure that..![]()
---------- Post added at 11:34 PM ---------- 6 hour anti-bump limit - Previous post was at 10:47 PM ----------
If the HWL is within your budget, make sure you buy it from a person who'll help you install properly. Preload the spring tension, adjust the bodyshift height (if the HWL has that) and replace the absorber mountings. The dampening rates can be adjusted yourself after everything is done.
A poorly setup coilover is kinda pointless too. If you don't have an installer who can do all that properly, you're better off with the sachs / monroe. Cuz preloading and bodyshift isn't something you can do on your own unless you have the time and the tools.
Ok, will try to look for HWL and for proper installer...![]()
