Review: Everco race exhaust + remote controlled valve in our Clio 4 RS
on the Galant? wow.
How has it been so far? I'm sure you needed a muffler or 2 replaced over the 1 and a half decade?
That's like the exact age of ZTH itself
Yup, transplant the engine in 2000, exhaust from turbine 2.5" straight to rear straight thru' muffler. Only muffler is stainless stainless steel, pipe is iron. Sound have changed since fiber glass in muffler have degraded...:driver:
That's long time ago haha
Since fibre glass degraded, the muffler sound.....
Mine at 110kph, the radio also have to crank up, exhaust too loud.....lol
That is why got remote controlled valve then can silence the exhaust a bit......lol:biggrin:
Weleh, 30 is very loud leh! I normally listen to vol 20, max 25 and already pretty loud with my seats vibrating already.
For my radio 20 is very soft actually lol
Radio from 1995 bro, have CD player some more
Dunno if its even working, need to try a CD in :biggrin: :rofl:
True also, different brands from different era, control numbers are different......:smokin::biggrin:
Yah true, the volume gain can be different and the voltage output also can be different. If using 4V output or higher like mine and gain matched with power amp, then volume 20-25 is quite loud already.
Yeah true. Just that the car muffler is quite bassy so when cruising at 3000rpm, recommended go faster. Just pros is that you won't hear much when you're at boost because the turbo itself will muffle the exhaust sound but need to be at high rpms. So yeah, no choice but to raise the radio volume :biggrin:
