How does this apply to non-DSG auto transmission with tiptronic?? Is it ok to engine brake?
My wife's SUV is steptronic, so I use to drop gear to overtake, going down steep slope etc., less for engine braking.....
Thanks for the guide and help, Tom. I appreciate that.
I have actually tried something like this before when I am downshifting. Sometimes when the rev matches, the downshift transition is smooth. But there are also many times when the rpm is not high enough to rev match after I blip the throttle. So there is still some slight jerking as the RPM climbs slightly higher after I release the clutch.
I will try it again on tomorrow as I will be going for a long drive.
Good reply, then your situation is extremely easy to fix.
You are either:
Not jabbing the throttle hard enough:
- Not jabbing the throttle hard enough. (note jab action, not press)
- Not releasing the clutch quick enough (therefore revs drop)
The rate at which the throttle is pressed is extremely important and determines how fast the engine revs climb. What we want is a sharp rev climb. Throttle response also differs vastly from car to car. So it's ever more important to know the throttle pedal.
Why we need a sharp rev climb:
The way an engine revs differ:
- To achieve the desired rpm range in the shortest time possible
- To take advantage of the very short window / time we have between clutch on and clutch off.
Not releasing the clutch quick enough:
- Linear Climb: When throttle is normally pushed / pressed
- Sharp Climb: When throttle is jabbed / poked / prod / jerked
This is a common problem, many drivers don't release the clutch quick enough. This delay results in drop of engine revs, therefore a mismatch in engine speed and wheel speed. - failure to capitalize on engine revs
A point to remember is when the throttle is blipped and when the rpm is at its highest desired range is when the clutch needs to be fully released. Never after or before.
try it Renesis
Wah! learning a lot, Very soon bro. Renesis becomes terror of Ipoh......hhahhahahahhahahhaha
My CLA is using 7 speed DCT. In sports modes, It will downshift a few gears progressively as I applied brake to enter a corner. All these happen at the same time, you can feel the downshift from the inertial force. The sound of the exchaust is louder as it keep downshifting, giving further hint on when exactly the gear downshifted.
I believe using manual transmission, you can applied all type of brakes together as long as the gear shift is progressive as what many has pointed out.
My other manual car, I usually applied brakes and hardly using engine braking. It's a slow car anyway.
This is Tom the racer talking not Tom the owner. Haha!
So, basically your CLA applies engine braking automatically without your input?
Actually i think the more modern cars with DSG or auto tiptronic, will downshift itself when you step on the brake. My car also like that, but of course, it is not as fast as when you do it yourself. There is a lag between the time you brake and the time it downshift itself. Ok for when daily driving. But if spirited driving, change to manual mode and shift yourself is better....![]()
My wife drive the SUV in D, but when I drive it, normally goes to the + and - side......hhahhahhaha![]()
Hehehehe...Proves that the racer/touge devil is in you....![]()
Tried rev matching today for many times throughout my drive. Initially I am still not used to it but as I try it on, I seemed to get the hang of it.
When the rev matches, the downshift transition is very smooth without any jerking or lurching at all unlike normal downshifting. Just the engine noise is slightly louder (more like sound from intake) because I jabbed the throttle.
But there are also several times when I am going at lower speeds and I tried rev matching but I end up jabbing the throttle too hard which resulted the RPM to jump higher than the matching point. That makes my car jerk slightly forward.
For now, I think rev matching is a bit difficult to pull out at lower RPM like under 2500RPM.
Good to know you're trying hard Renesis
Okay, as mentioned,
The higher the gear the less the blip
For example,
What you can experiment now to determine the rev range at which you should be blipping:
- 6th to 5th : blip level 1
- 5th to 4th : blip level 2
- 4th to 3rd : blip level 3
- 3rd to 2nd : blip level 4
- Drive at 100km/h on 5th gear and note RPM range (e.g.: 2500)
- Drive at 100km/h on 4th gear and note RPM range (e.g.: 3500)
- Now you know what rev range you're at at a certain gear number
- Then proceed to drive and maintain at 100km/h in 5th gear
- Try dropping to 4th and blip throttle between 3500-3700
- Adjust footwork to find sweet spot
- You should be able to repeat this smoothly from now on
Good luck
Bro. Renesis have our famous Wila loh......![]()
| hi i wanna sell my evo 9 manufacture year 2005 register year 2006 import baru ap baru stock standard accident free aluminum roof mivec turbo 6 speed regular service recaro leather seats cd... |
