need help EVO tb
mottrang
hi all...
i need guidance about installing evo tb on my ride...
std tb got 3 nipple for vacuum line but evo oni 1 nipple mark at 'P' oni...
if i jes terminated the 'E' and 'A' nipple wat will hapen.... :hmmmm:
thanx in advance...
nothing will happen...i've even blocked the water passages to the throttle body after installing an aftermarket tb.
Hai sifus..sry to up this old post..
I need help on putting evo3 tb on 4g9xp.
The problem is the vacuum hose bcoz 4g9xp need vacuum hose to connect to part at firewall.what i need to do since evo3 tb only got 1 nipple at 'P'?
Sent from my Redmi Note 2 using Tapatalk
I have seen mechanic actually blocking some of the vacuum but your case more to less. What I mean is less to more so he just block with a small screw....
