It is good being objective and not biased. Perhaps that is why you can do well in Malaysia. ...
Never heard of Advan V105 before. ...
So, I guess to ensure good grip in all conditions on the road, the best one can go for will be max category?
Normally tyres without grooves are considered as above max already isn't it? Like R1R?
Ok la, I'm doing enough just to get by in life, still very much struggling kuli.
Advan V105 is the second generation/improved Advan Sport (full name Advan Sport V105).
Yah above Max already starting to loose performance in the wet coz too focused on dry grip (extreme, then semi slicks, then slicks).
I think wet grip depends on grooves to channel away water isn't it? Parada Spec 2 only has 1 groove... If so, then tyres like R1R certainly fares very poor in wet...
Grooves and compounds as well. The grooves are mainly to channel out water and therefore to resist aquaplaning. But the compound also needs to stick on the wet surface if got no water puddles or once the water already channeled out. Wet performance got 2 aspects: aquaplanning resistance if in very wet/heavy rain with puddles, and also grip in the wet surface without puddles. PS3 is well known for the best in aquaplaning but not necessarily also the best for grip in the wet surface without puddles. CSC5 in the reviews has better grip than PS3 in the wet surface without puddles but PS3 has better aquaplaning resistance.
