4G93 DOHC with intake and exhaust reversed?
But he did change the block too. If you look at the top radiator hose, it is going to the back of the engine at the firewall
Nope. Just head swap. The top radiator hose goes into the head.
Stock head top hose goes in like this:
Now how he manage to fit the water and oil passages from head to block....:hmmmm:
Nope, that is not a CK head. Initially I thought so too but after looking carefully, I found out that the head (valve cover) is from the old 4G9 series not the new 'terbalik' version.
Here, look at this area that I highlighted. There is this gap area to accommodate the plug cables in the earlier 4G9 series engine.
attachment.php
attachment.php
But it is not present in the CK series of 4G9 engines.
attachment.php
the pink color engine bay, how they hide all those wiring, piping ....etc. Look clean :listen:
is it all hide under/inside the car frame...what if need to do troubleshooting
i still prefer look at wiring, cables, piping and scratch my head. :biggrin:
Maybe all the auxiliary parts for the engine are taken out? Like this is a track car... No power steering, no air cond, battery relocated to other place? Hence less wiring?
the pink engine is CK version.. then they mate it the whole engine with CA gearbox (normal wira/satria layout)....and use back the CA version normal valve cover.....just to play eye trick on you guys.... :biggrin:
So, it is a CA gearbox and block but CK head with CA valve cover? I'm surprised the CA valve cover can fit in nicely.
ca gearbox, ck block, ck head, ca valve cover nicely done mix n match
CK block? But CK block's flywheel area is on the opposite side of CA block. Unless this person really reversely mounted the CK engine to achieve this setup?
as i said....just rotate the block 180 degree from its ori position and use back CA gearbox....
