does evo 3 actually has a 02 sensor? might be this if true..
how do I know if its faulty? via reading?
If O2 sensor CEL should light up.....
hey hey, checked.
with another air flow sensor, also the same.
with air flow.. 0.5
no air flow, 1.0
If O2 sensor CEL should light up.....![]()
Hmm... Is ur airflow sensor compatible? Previous owner changed anything inside?
Sent from my SM-N9208 using Tapatalk
current using standard evo 3 air flow sensor.
previously, don't have.
he was using safc 2, engine was heavily mod.
tried using my friend's evo 3 air flow sensor, still the same.
your car had safc right? maybe require proper tuning...
im still around bro.....
your NSK coil pack is suitable for evo3?
you found the problem bro? i think u need to install sfac gua...
kurt,
u should have not sold the safc2 as its very useful
did u manage to solve the issue?
kurt,
That is some tricky issue you got there
in that case leave out the safc at the moment, have you check your routing of you boost vacuum hoses?
trying using "tulang ikan" can buy at aquarium shop, use youtube to install, quite simple, just a few meters of silicon hoses & some T plastic adapters.
Yeah.. been there, done that.
Also cannot..
My friend helping me to bring the car to kulai. . See what does the mechanic got to say
