Pedal to the floor, I get about 180-210km per RM60 worth of RON97 (current fuel price).
Doesn't sound so bad considering how powerful it is.
Bore and stroke is displacement. Does not mean short stroke use less FC. In fact long stroke have better low end torque, short stroke have better acceleration due to faster revs. Both have it's pros and cons.....![]()
It is like what I heard from F1 engines. They have very short stroke so that they can achieve higher revs. Shorter stroke also means a shorter distance of travel for the pistons from bottom to top right?
Close ratio means you don't have long overdrive gear, therefore cruising at higher speed means running high revs consuming more fuel.
VTEC to open is like after 5k rpm, means you are flooring most of the time, FC will be good???![]()
If so, I don't think these engine can sustain long distance travelling at high speed since RPM is always high. Might overheat the engine.
Not expecting the FC to be good. Just want to know how bad can the FC become if always floor it and open VTEC. From what he said, it doesn't sound so bad. Some higher displacement engines consumes even more fuel even during normal usage.
can anyone give a hint...thanks...
