- Joined
- Dec 2, 2005
- Messages
- 303
- Points
- 3,018
Proton Perdana 1997 For sale
Already restored in super mint condition, just buy and drive.
Engine / Gearbox :
Overhaul COMPLETE REBUILD 1jz Piston (Ring Gapped to my personal specification for no oil consumption)
Stock Conrod
Port and polished head to mirror finish for super high airflow
ACL Bearings
Timing Belt + Water Pump TD04l + 19t billet compressor wheel
Stainless steel intercooler pipes + Apexi Intercooler + silicon hoses
Banana Custom
Ori Tial wastegate 38mm
Goodyear Gatorgrip Belts
Perdana ori 2wd manual gearbox
New Clutch Pump top and bottom
Solid Full Rubber Mounting rear for engine
Shortshifter + aluminium gear lever washers, not rubber
Aluminium Thick radiator
Iridium Plugs
Walbro 255lph fuel pump + evo injectors
Adjustable Fuel pressure regulator
New Throttle body ISC Motor
E-manage blue, works manual boost controller
Engine has been well taken care of, only ran fully synthetic from Motul/Amsoil
Aircond flushed with machine, super cold, running on synthetic compressor oil
3 inch stainless steel exhaust with apexi muffler
Suspension / Tires :
CE28 9jj rims
Goodyear Eagle F1 Assymetric 2 235 45 17 Tires, front 70percent rear 40percent
Front Mitsubishi GTO 6speed(rare) 4pot brakes with 313mm discs
Rear Mitsubishi GTO 6speed(rare) 2pot brakes with 296mm discs
EBC Ultimax brake pads front and rear All lower arms running on SUPERPRO PU BUSH, less than 10000km (spent 5k on this)
Adjustable front camber arms
BC Racing BR Coilovers adjustable front 8k rear 5k springs (2 years old)
Ultra racing Rear 23mm anti roll bar
Ultra Racing Fender Bars
Eterna front strut bar
Entire chassis foamed for better handling and less tire and external noise
Interior / sound system / Alarm :
Perdana V6 original leather seats
Perdana V6 floor carpets
Full soundproofing (worth RM7k) on all doors, roof, floorboard, with the proper materials from STP(bomb, top range). Bukan buat tepi jalan. Easily, the quietest perdana on the road without any creaks or squeaks or tire noise.
Alpine Headunit cd player (1.6k)
German Maestro front component set (RM1.4k)
15inch subwoofer Alpine type-r
Audison Amps
Photochromic tint from Chameleon (turns dark under sunlight)
Custom Leather gear shifter cover
Well kept interior, no kids
Leather and dashboard moistured with Meguiars Leather conditioner every month
Steelmate Alarm with autostart feature
Turbo Timer, Boost Meter mechanical
New Door Rubber seals on all 4 doors, bought original, not fake (2 years old)
Anti Hijack and Tracking system(will be removed)
Exterior :
Car has been painted with Mazda 3’s pearl white (code 34k). Looks like solid white under normal circumstances, but glitters like diamond under sunrise or sunset
Coated with 4 layers of PPG’s hardest clear coat, took 1 month to dry before polishing. Mirror finish. UV Resistant. Wont turn yellow after years.
Waxed every 2 months
Projector headlamps
OEM Perdana Rear Reflector & Tailamps with LED light bulbs
Perdana V6 OEM ORIGINAL bodyparts, not fake.
Sound system, anti hijack and tracking system will be removed.
Asking price may be abit high as I want to find a new owner that would take good care of it.
RM22,000.00. Name change sendiri kautim. Puspakom I do.
On top of the above, a pendrive containing my car’s photo progress on modifications and restoration will be presented to you.
Reason for sale : too many cars. No time to drive.
Pendek kata, power bukan tinggi, tapi low end torque ada. Boleh makan golf gti mk7
Lokasi Subang
012-9096996 Elton
*sorry for the malay language mixture*.
Engine / Gearbox :
Stock Conrod
ACL Bearings
Banana Custom
Iridium Plugs
CE28 9jj rims
Audison Amps
Exterior :
Projector headlamps
Lokasi Subang
012-9096996 Elton
